PLC learning
Discussion in 'The Projects Forum' started by muhanad, Mar 1, 2014.
  1. muhanad
    Mar 1, 2014
    hi, who can help me to get more learning refrence for plc programming plz. i worked on zelio and built some simple circuits like starting motor circuit an star delta starting, and i want to use an analog input and output signals.... the plc that i use is zelio plc v4.2. thanks for all
    Eng.Muhanad
  2. LETITROLL
    Member
    Oct 9, 2013
    218
    Hi here is a very useful book am currently reading
    http://depositfiles.com/files/alrbsg2rv
    In the other hand i would really appreciate it if i cant get a link for one or more of these books :
    -vector control of three phase ac machines
    -Introduction to bond graphs and their applications .
    -System dynamics: a unified approach
  3. MaxHeadRoom
    Jul 18, 2013
    10,860
    2,525
    The Zelio is one of the Smart Relay branch of products.
    All PLC's have their own programming idiosyncrasies, so I would recommend either getting some actual practice on a actual unit or if you have access to the PC software, which it seems you already have, then get some practice this way writing a program.
    As all a book on PLC's in general is only going to give you an overall feel for typical programming, but not specifics for your unit.
    It is best to study the actual instruction sheet for the module you intend using.
    Max.
  4. LETITROLL
    Member
    Oct 9, 2013
    218
    There is also PL7 if the PLC is from schneider brand .
