PLC ladder diagram help
Discussion in 'The Projects Forum' started by neededLotsofhelp, Jun 22, 2015.
  1. neededLotsofhelp
    Jun 22, 2015
    I'm doing this for the first time and needed LOTS of help in it. I'm currently using a panasonic fp7 series plc, panasonic gt series touch screen and a cloud 4700f card reader for my project. The attached file is a sample of my flowchart needed to create a ladder diagram. I truly hoped that someone would help me or show me a sample of how the program is gonna be like. I'm really in balls deep. Please help thank you.
  2. MaxHeadRoom
    Jul 18, 2013
    10,844
    2,521
    I am not familiar with the Panasonic, but there are plenty of getting started video's on the web etc.
    You need to put together a list of the input devices you may need, Start PB, Stop PB etc and then preceed to write each function into each rung one rung at a time.
    You really need access to a trainer PLC or one you can rig up temporarily in order to make any headway.
    Max.
  3. neededLotsofhelp
    Jun 22, 2015
    Thanks for the video link max. I got a question if you know anything about card reader programming. What would the ladder be like for a card reader to work? Really appreciate your reply thanks alot.
  4. MaxHeadRoom
    Jul 18, 2013
    10,844
    2,521
    I assume you mean interface a card reader with a PLC?
    I haven't done anything in this area, but if the PLC has Modbus capability, this may be one option to look into.
    Max.
  5. neededLotsofhelp
    Jun 22, 2015
    Yes it do have modbus capability
  6. RJohnson
    May 29, 2011
    21
    Before I switched to microcontrollers I did a lot of PLC work. You have made a start with a flowchart.
    I suggest adding list of what goes where physically and then what is available to link things together with for communications.
    You do have a task ahead but it is doable. Allow yourself some learning curve time. :)
