PLC-Based Control System for a Three-Phase Induction Motor
Discussion in 'Embedded Systems and Microcontrollers' started by Brend123, Jul 17, 2015.
  1. Brend123
    Jul 17, 2015
    Hi..., I have a final year project which is a PLC-based control system for a three-phase induction motor. I have an electromagnetic brake on the shaft of a 380 V, 6.63 A, 3.0 kW induction motor. The plan is to get maximum efficiency on different load conditions. I have written my PLC program already, and plan on testing the efficiency on 5 different rpms with 3 different load conditions on each speed. I need a control system for the brake, can anyone help me please? I need to be able to give instructions from the PLC.
  2. strantor
    Oct 3, 2010
    4,302
    1,989
    provide info about the brake and the PLC.
    Model# of brake, datasheet, manual.
    Model # of PLC, installed options, communications, etc
  3. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,523
    How do you intend obtaining/controlling the 5 rpm ranges if this is a standard induction motor?
    If using a brake to do this then basically this is a Dynomometer?
    And range will be very limited.
    Max.
