plate saturation?
Discussion in 'Homework Help' started by Bigcountry, Jul 10, 2008.
  1. Bigcountry
    Thread Starter Active Member
    Jul 4, 2008
    71
    I am studying triode plate saturation and I am stuck on this question :
    Plate saturation is the condition when :
    (1) plate power dissipation is maximum recommended for the tube type
    (2) secondary emission from the plate equals cathode current reaching the plate
    (3) plate current does not further increase when the grid is made less negative
    (4) maximum plate voltage is used
    I think it might be 1 or 2.
    In a vacuum tube, the space-charge-limited current, such that further increase in filament temperature produces no specific increase in anode current. In a vacuum tube, the temperature-limited current, such that a further increase in anode-cathode potential difference produces only a relatively small increase in current.
    Maybe I am not seeing something again. thanks for any helpful hints.
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    I would have thought the plate was saturated when increasing the grid drive does not further affect the plate current. That would be the equivalent of signal clipping.
  3. JoeJester
    Apr 26, 2005
    3,393
    1,211
    I'm with beenthere. Saturation has always been when the increase in drive signal does not effect a further increase in plate current ... your answer number 3.
  4. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    From Ye auld NEETS module 6:
    Man are my NEETS modules dusty!
  5. JoeJester
    Apr 26, 2005
    3,393
    1,211
    Update your dusty neets modules from the pdf's at davidson college.
    Of course the other option is the 1998 CD version.
    I'll have to check with nko and see if the pdf's at their site are more current than the pdfs at davidson college.
  6. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
  7. JoeJester
    Apr 26, 2005
    3,393
    1,211
    They always do ... and nko has updates ranging from 1998 up ... for the NEETS pdf's.
  8. Bigcountry
    Jul 4, 2008
    71
    oh ok. Now that I see the answer I understand it better thank you.
    That would be if the grid is goes from -4 to -2. there would be increasing the grid but not increasing the plate current.
