Plastic deformation
Discussion in 'Homework Help' started by Hello, Jan 13, 2009.
  1. Hello
    Thread Starter Active Member
    Dec 18, 2008
    82
    Describe how plastic deformation occurs in metal.
    I know that,
    Is the deformation that is permanent after release of applied load.
    Point where stress is no longer proportional to strain.
    But not sure how you can relate it to metal.
    Any help is greatly appreciated.
  2. studiot
    Nov 9, 2007
    5,005
    515
    Don't know of a simple explanation for this one. You need to know a deal about crystal structure.
    If you consider the crystal structure and the bonds as vector lines of bonding force, the vector sums add up to different strengths in different directions. There are planes where the bond strength sums are definitely weaker.
    Tension exerts shear stress diagonal to the line of the tension. If you examine the crystal structure, after plastic deformation, it should come as no suprise to learn that small failures known as slip planes can be observed along these planes of weakness.
    Look up slip planes.
