Plasma TV No sound or image and clicking noise
Discussion in 'General Electronics Chat' started by tliky, Nov 25, 2012.
  1. tliky
    Nov 25, 2012
    Hello all,
    I have the Samsung Plasma and as the title mentioned, it has no sound nor image. Based on what I have found, it should power module's problem, but I could not find any blown fuse or cap. Any suggestion on what I should do?
    Thanks!
  2. kubeek
    Sep 20, 2005
    4,691
    806
    Look which caps look bulged on the PSU module and replace them. If you don´t see any then you need an ESR meter, or if you have a shop close by change them all.
  3. sheldons
    Oct 26, 2011
    616
    101
    before going too deeply,disconnect the leads to the y sus and z sus panels and see if yr set powers up......chances are you may have a failed sustain panel in which case replacement panel and driver may cure your set......
  4. Dodgydave
    Jun 22, 2012
    5,167
    777
    Start by measuring the voltages from the power supply , they usually have test points marked.
