Planetary motors
Discussion in 'General Electronics Chat' started by Dritech, Mar 28, 2013.
  1. Dritech
    Sep 21, 2011
    756
    5
    Hi all,
    Do planetary geared motors rotate both directions? because I am seeing drawings indication an arrow to one side.
    Also, do Planetary motors lock like worm motors? Lets say for instance the motor will be used to rotate a pulley which will be used to lift a load using a rope. Will the load go down when the supply is turned off, or will the planetary gears prevent this (lock) ?
    Thanks in advance.
  2. crutschow
    Mar 14, 2008
    13,482
    3,369
    If the motor can rotate in both directions then so can the planetary output. Planetary gears rotate equally well in either direction.
    No, planetary gears don't lock like worm gears.
    shortbus likes this.
  3. Dritech
    Sep 21, 2011
    756
    5
    Thanks for the reply crutschow .
    So basically I have to do some kind of braking system to hold the load right?
  4. crutschow
    Mar 14, 2008
    13,482
    3,369
    That is correct if the load generates enough torque to back turn the motor through the gears.
    Dritech likes this.
  5. BillB3857
    Feb 28, 2009
    2,402
    348
    Depending upon the planetary ratio, it may not take much of a brake on the motor end. Remember, the torque is multiplied (motor to output) by the gear set when the motor is driving and divided (output to motor) when the load becomes the drive.
  6. THE_RB
    Feb 11, 2008
    5,435
    1,305
    That's true, but a "rope on a pulley" can have significant leverage and is one of the worst cases for backdriving. Likewise if it does start to move it will accelerate badly, anothe r worst case laod for backdriving. Even a worm drive can have issues with that type of load.
  7. Metalmann
    Dec 8, 2012
    700
    223
    Planetaries go/run in both directions, unless impeded by a stop mechanism.
    You can also use a one-way bearing, to hold position.
  8. shortbus
    Sep 30, 2009
    4,092
    1,673
    Automatic transmissions in cars are a good example of this. Sprag clutches and one way rollers plus planetary gears.
