Plane parachute
Discussion in 'Off-Topic' started by nsaspook, Jan 26, 2015.
  1. nsaspook
    Thread Starter AAC Fanatic!
    Aug 27, 2009
    3,013
    2,357
  2. #12
    Nov 30, 2010
    16,685
    7,323
    Swell parachute. I only wish it had reminded him to fill the gas tank. :D
    Still, he was lucky he didn't have to be anywhere near Washington D.C.
    A government employee was playing with a toy quad-copter today and every channel on my TV is having a terror crisis threat about it tonight.
  3. jpanhalt
    Jan 18, 2008
    5,699
    909
    The Cirrus is one of the new breed of private airplanes that boasts a ballistic parachute for emergencies. Running out of fuel seems about the easiest thing not to do, yet such pilot errors are 5 times more likely than mechanical failures as the cause of crashes (http://www.ghafi.org/download/GA-Analysis.1.pdf ).
    In one incident I witnessed, a pilot flying from Louisiana to St Louis asked for priority landing at Spirit of St. Louis airport in the early 1970's. I was #1, but was made to circle. As soon as he landed and the nose of his airplane rose (he was in a Piper Cherokee/Arrow) his engine stopped on the runway and he had to be towed to the ramp. I was flying from ROC and had made a fuel stop in Columbus, even though my airplane had the range in theory to go non-stop. Running out of fuel is capital stupidity in my book. A fuel stop may delay you a little bit, but it has so many other advantages to offset the 15 to 30 minutes it takes.
    John
    cmartinez likes this.
  4. #12
    Nov 30, 2010
    16,685
    7,323
    Amen!
    but I have a brother-in-law that came to mind immediately when I saw this on TV.:rolleyes:
  5. spinnaker
    Oct 29, 2009
    5,074
    1,176
    According to the pilot, he had plenty of fuel. Apparently fuel was just not getting to the engines.
    There was another inter-island crash on the same day where they did run out of fuel.
  6. MikeML
    Oct 2, 2009
    5,451
    1,066
    If he was 253 mi from Maui, that doesn't sound like an inter-island flight. Wonder if he was flying California coast to HI?
  7. spinnaker
    Oct 29, 2009
    5,074
    1,176
  8. spinnaker
    Oct 29, 2009
    5,074
    1,176
    Guy with parachute was flying from CA to HI.
  9. GopherT
    Nov 23, 2012
    6,309
    4,029
    Ok, something is strange here. Strange about the pilots decisions and why he made them.
    Cirrus says their plane (SR-22) has a range of 800 miles including reserve at full speed and minimum payload. 40% extra at 2/3 power.
    And the distance from LA to Maui is way more...
    And, go figure, he ran out of fuel 1000 miles NE of Hawaii.
    Am I missing something in how fuel range is calculated at other altitudes or payload?
  10. #12
    Nov 30, 2010
    16,685
    7,323
    post#5 by spinnaker: He did not run out of fuel.
    Apparently you can triple the distance on an 800 mile gas tank when flying down hill, as clearly shown by the map in post #9. Unfortunately, 2400 miles was not enough for a 2,490 mile trip. :rolleyes:
    GopherT likes this.
  11. spinnaker
    Oct 29, 2009
    5,074
    1,176
    That was the pilots claim. Not saying it was reality.
  12. JohnInTX
    Jun 26, 2012
    2,394
    1,051
    From a Honolulu report:
    Ferry flights have additional fuel tanks temporarily installed in the baggage compartments and/or passenger area. Transfer pumps are used to pump the ferry fuel into the main tanks of the plane where its used normally. If a valve or pump fails, you have problems but at least time to sort them out while burning off the remaining fuel in the mains. Reports say the pilot had enough time to declare an emergency and get things right - including getting close to the cruise ship before ditching. There have been a few other ferry incidents over the years due to the same kind of problem. From a distance, it looks like the pilot did everything right. My guess is that once the rescue was set up, he shut it down and popped the chute. Good job.
  13. spinnaker
    Oct 29, 2009
    5,074
    1,176
    It at least looked like a tiny plane. Hard to imagine it could could enough fuel for such a long trip.
  14. #12
    Nov 30, 2010
    16,685
    7,323
    Ooh! Complicated math!
    A thousand pounds of extra fuel and a 180 pound pilot cuts the range down to 100 miles, but the "payload" weight of fuel is constantly dropping and it is added to the original specification of 820 miles and multiplied by 1.4 for running at 65% throttle.
    I could take 5 minutes just to figure out the equation. Maybe that's why pilots have to study piloting. ;)
  15. jpanhalt
    Jan 18, 2008
    5,699
    909
    You can fit accessory tanks (sometimes called ferry tanks) in many aircraft. The Cirrus is quite a small airplane. I son't have a clue as to whether it can be fitted with ferry tanks.
    John
  16. GopherT
    Nov 23, 2012
    6,309
    4,029
    More like, pilots learn how to use little charts prepared by engineers...
    ..and why engineers study calculus.
    #12 likes this.
  17. MikeML
    Oct 2, 2009
    5,451
    1,066
    I have flown a Cessna 206 (high-wing, single-engine, turbo-normalized) that was ferried from HI to Oakland, CA. A 400 gallon rubber bladder tank is put on the floor (to spread the weight) right at the C.G. A small 24Vdc pump is rigged to transfer fuel from the bladder up into the wing tanks during flight. The aircraft takes off over-gross weight, so a FAA ferry permit is required. Single pilot, life raft aboard.
    I was at the Oshkosh fly-in and talked to homebuilder Jon Johanson that flew his RV4 from Brisbane to Oshkosh (twice). His longest leg was from HI to CA.
    I worked at HP with Chuck Kingsford Smith, whose father first flew the other way in 1928.
  18. MrChips
    Oct 2, 2009
    12,633
    3,453
    Sounds like a differential equation. Do pilots have to study calculus?
  19. WBahn
    Mar 31, 2012
    18,087
    4,917
    One thing that a lot of people overlook is the effort that was put into rescuing this one person out in the middle of the ocean (okay, so "middle" is a bit of a stretch). The FAA notified the Coast Guard and dispatched a C-130 and contacted a cruise ship that threw it's schedule out the window and went to the serve as the rescue ship. This is typical response. A decade or two ago the pilot of a Cessna got disoriented and ended up way out to the east of the East Coast over the Atlantic and the Navy diverted an entire carrier battle group that was within range to intercept him. I don't recall for sure, but I think the pilot ended up landing on the carrier because the captain determined that that posed less of a risk to the pilot than ditching in the sea. I can't find a reference to the event, but I found some sites were a few others commented on (what appears to be) the same story.
    You see this all the time. A missing hunter, hiker, skier, elderly person with dementia, whatever and you immediately have search parties that can number into the hundreds with numerous aircraft in support. Most of those searchers are volunteers, but not all of them. Corporations often get into the act, often in a support role by supplying, or at least paying for, food and such to support the searchers and in many cases will send their own aircraft to assist in the search provided they can get a suitably trained pilot (who sometimes has no affiliation with the company and is just a search pilot that doesn't have a plane available (the normal case on a search -- more pilots than planes).
    There aren't that many countries that will put forth that kind of effort to save a single individual -- says quite a bit about those countries that will.
  20. joeyd999
    Jun 6, 2011
    2,756
    2,925
    Probably in the same way that baseball pitchers do.
