Placing suffix u with unsigned variables
Discussion in 'General Electronics Chat' started by aamirali, Feb 4, 2014.
  1. aamirali
    Feb 2, 2012
    415
    I was reading on misra website that for assigning 0 to unsigned variable, 'u' must be suffixed.
    For example:
    Code ( (Unknown Language)):
    1. uint8_t my_cnt = 0U;
    1. Does that even on declaring array I should use this.Like
    1. uint8_t my_arr[10U];
    2.
    2. Also while using switch cases like:
    1. void func(uint8_t no)
    2. {
    3.     switch(no)
    4.     {
    5.          case 1U:
    6.          break;
    7.
    8.          case 2U:
    9.          break;
    10.
    11.     }
    12. }
    If yes then what if variable passed to switch is of int8_t type. In above example if
    1. int8_t no;
  2. tshuck
    Oct 18, 2012
    3,531
    675
    0 is a 0 is a 0. The U just tells the compiler that this number has to be unsigned. The compiler will determine what representation (and size) is required to match the implied number.
    In other words, it isn't necessary to put something like
    1.  uint8_t x;
    2.  if (x == 1U)
    3.     break;
    unless your compiler is trying to use a signed number where an unsigned is needed (which would be very rare - and almost always result in a warning).
