PLACEMENT OF AC BLACK&DECKER7190 TYPE 2 INSIDE WIRES
Discussion in 'General Electronics Chat' started by billmill5050, Sep 1, 2014.
  1. billmill5050
    Aug 31, 2014
    6
    I HAVE A B&D 7190 TYPE 2 VSR DRILL .IT HAS A BLACK WIRE & A WHITE WIRE ( THAT WAS CHANGED TO RED) COMING FROM CORD, IT HAS A TRIGER SWITCH WITH A 4 AND 1 ON ONE END AND A 2-3 ON THE OTHER END .IT HAS A JUMBER WIRE GOING FROM 3 TO LOAD .NOTHING IN THE LINE HOLE .IT HAS A FORWARD ,REVERSE TOGGLE ON TOP OF TRIGGER NO WIRES NEEDED.AND A RUN SWITCH UNDER TRIGGER. 2 FIELD WIRES AND 2 BRUSHES, I NEED TO KNOW WHERE TO CONNECT THE WIRES THANKS
  2. MrCarlos
    Jan 2, 2010
    400
    134
  3. jpanhalt
    Jan 18, 2008
    5,699
    909
    Your question will need pictures for us to understand. A photograph would be the greatest help. If you can draw what you have done to it, that would help too.
    For what voltage is this tool wired?
    All capitals is hard to read and some people object to it.
    John
  4. billmill5050
    Aug 31, 2014
    6
  5. billmill5050
    Aug 31, 2014
    6
    ON THE SWITCH IT IS MARKED LEFT SIDE 4 and 2 on the right side 1 and 3. . the bottom has a line and a load slot. there is a jumper wire from load to #3.does black wire from cord go to line? the other cord wire was changed from white to red. does that go to a field? not sure where brush wires go. and where is a white field wire not sure where that goes
  6. billmill5050
    Aug 31, 2014
    6
    120 v ac 3 amp 0-1200 rpm
  7. debe
    Sep 21, 2010
    955
    185
    ELECTRIC DRILL WIRING.jpg DRILL CHANGE SW.JPG DRILL SPEED.1.JPG DRILL SPEED.3.JPG DRILL.1.JPG This is what most reversible & variable drills are wired.
  8. billmill5050
    Aug 31, 2014
    6
    thanks ,I cant read sch. .that good .I really cant tell where wires are coming and going
  9. shortbus
    Sep 30, 2009
    4,086
    1,664
    Not to be mean or offensive, but then wouldn't it be better to take this to some one who can do it? Is doing it yourself worth your life?
  10. billmill5050
    Aug 31, 2014
    6
    oh ive done before just don't know path kinda hard to get a answer on here
