Place load under N Mosfet?
Discussion in 'General Electronics Chat' started by brucester, Jan 20, 2013.
  1. brucester
    Dec 24, 2012
    19
    On all circuit i look at, the load is always above the drain on an N mosfet.
    I dont like it because i dont get to use 0v as my ground.
    Is it ok to put the load under the source like with a p mosfet?
    Why dont ppl do it?
  2. Dodgydave
    Jun 22, 2012
    5,156
    772
    Loads are better connected in the Drain side as this will give the maximum current, if you use the Source side you will loose voltage due to the Gate/Source voltage drop.
