PK3Err0045: You must connect to a target device to use PICkit 3.
Discussion in 'Embedded Systems and Microcontrollers' started by Bob807, Aug 31, 2014.
  1. Bob807
    Aug 31, 2014
    I'm having connection difficulties also and was wondering if you resolved your problem? I get the response: "
    3." when using the MPLab X program to send the program to the PICKit 3. If I use "Flowcode" I get a response: No USB connected. Although the program that was origionally installe in the demo board with the PIC18F45K20 chip installed is running all the time from the power from the usb port through the PICKit 3
    bob
  2. mayilsamy
    Mar 26, 2013
    5
    Can you check once again the connections 1. MCLR , 2. VDD , 3.VSS , 4. PGC, 5.PGD.
    and also place 100nF across VSS and MCLR..
  3. jpanhalt
    Jan 18, 2008
    5,699
    909
    Are you sure the PK3 has been properly configured? Be sure the proper PIC device is selected. Then go to the tabs/menus: Programmer >Settings...>Power
    Be sure that you check power target (if you are powering your device by the PK3) and set the voltage.
    BTW, this is a very old thread. You might get better advice by starting a new thread.
    John
  4. ErnieM
    Apr 24, 2011
    7,435
    1,625
    OK, same question: post YOUR schematic.
    Please do so in a new thread, it's gets confusing not seeing "thread starter" as the person needing help.
  5. Bob807
    Aug 31, 2014
    I'll post in a new thread.
  6. MrChips
    Oct 2, 2009
    12,624
    3,451
    You don't need to create a new thread. Let a mod do it for you.
    ... there, you have a new thread.
  7. ErnieM
    Apr 24, 2011
    7,435
    1,625
    Too bad mods can't post his schematic too.
