PIV for Full Wave Rectifier (Quick/Simple)
Discussion in 'Homework Help' started by jegues, Apr 21, 2011.
  1. jegues
    Sep 13, 2010
    735
    43
    I've got a quick question about the PIV.
    Shouldn't it be,
    PIV = 2v_{S} - v_{D}
    This is a full wave rectifier, what he has got looks like what it should be for a Bridge rectifier.
    Which one is correct?
    EDIT: I've got it figured out I was misreading something in the original question.
    It also asks about what fraction of a cycle each diode conducts.
    On any half cycle the supply must overcome a voltage drop of 0.7V.
    wt = sin_{-1}(\frac{0.7}{12\sqrt{2}})
    So the fraction of a cycle that each diode conducts is,
    \frac{\pi - 2wt}{2\pi} * 100 = 12.38%
    Is this correct?
  2. Adjuster
    Dec 26, 2010
    2,147
    300
    NB indeed this is not a bridge rectifier: the lost voltage is one diode drop, not two. The calculation in your attachment shows two diode drops, which is wrong.
    Each diode therefore conducts for half a cycle, less the time that the 12V rms AC is less than one diode drop. You seem to have taken the "lost" conduction angle due to the diode drop to be the total. Think again.
  3. jegues
    Sep 13, 2010
    735
    43
    Let wt = \theta
    \theta = 0.0412rad
    \frac{\pi - 2\theta}{2\pi} * 100 = 48.69% \text{  for EACH diode}
