PIR Sensor to trigger switch and timers
Discussion in 'General Electronics Chat' started by PaulCullen, May 15, 2013.
  1. PaulCullen
    May 15, 2013
    Is there a way to get a PIR sensor to open a circuit when triggered and at the same time trigger 2 countdown timers. The 1st countdown timer will close the circuit after 10 seconds and the second countdown timer will open the circuit after 20 seconds.
    The PIR and Timers all run on 9 to 12 VDC.
    The circuit is on a standard 220 to 240V and 50 to 60Hz
    I would really appreciate some help :confused:.
  2. Dodgydave
    Jun 22, 2012
    5,166
    775
  3. crutschow
    Mar 14, 2008
    13,509
    3,385
    What is the PIR sensor signal level?
