I have a project with 3 PIR sensors that worked great for it's first weeklong installation but the second time I installed it...one segment simply behaved irrationally. PIR seemed not to be communicating with the Arduino UNO though the other 2 communicated fine with their respective Unos (3 total) and each runs the exact same program. The power to that one set seemed to be erratic too but it was still getting power. Power was supplied to all 3 sets through the same wall wart and only 1 seemed problematic. I replaced the PIR and Uno with new ones and then it didn't work at all.All contacts had continuity and the wall warts tested fine too. I reloaded the program repeatedly, turned power on and off, tested continuity on everything, and still no results. Exhausted my limited knowledge base and had to leave the project only partially functioning. Not sure what else to do...could it be the Arduino? The fact I used a switching type power supply? I learned enough to build it, but I don't know enough about electronics to figure it out how to solve unexpected behaviors! Any suggestions about what went wrong?
