PIR question
Discussion in 'General Electronics Chat' started by mbohuntr, Oct 28, 2010.
  1. mbohuntr
    Thread Starter Active Member
    Apr 6, 2009
    413
    32
    I am finishing the connections on my camera trigger project, and ran into this?? The directions said to use a pullup resistor on the alarm output of the PIR, so I connected it to pin 3 of the 555 along with a 1M ohm resistor and it stays low? (The 555 trigger pin gets pulled low) Is my resistor too large?? Sorry for the crude drawing, I'm too tired for multisim.
    http://www.sparkfun.com/commerce/product_info.php?products_id=8630
  2. gerty
    Aug 30, 2007
    1,154
    304
    Yeah 1 meg sounds too high, without knowing how much current the pir can sink (not in data sheet) it's just a crapshoot. I'd try something like 10kΩ
  3. mbohuntr
    Apr 6, 2009
    413
    32
    Thanks, one of the message posters on that link said something similar. I'll keep you posted.
  4. mbohuntr
    Apr 6, 2009
    413
    32
    No good, I think something else is going on.. This unit uses a 5v regulator. If I am supplying 5v from the benchtop, then would the regulator stop working? I went from a 1M pullup gradually down to 10K, but I don't dare go lower. It is still pulling the voltage down. If it's working correctly then it should swing from 5v-0v right?
  5. mbohuntr
    Apr 6, 2009
    413
    32
    GOT IT!! The regulator doesn't work properly until over 7 volts or so. I guess I'll use a separate power supply for the PIR. Thanks for the help.
  6. gerty
    Aug 30, 2007
    1,154
    304
    I love it when a plan comes together...
  7. campeck
    Sep 5, 2009
    194
    yeah, regulators have a dropout voltage you need to be aware of.
  8. Bernard
    Aug 7, 2008
    4,240
    414
    I may be nuts [confirmed] , but it looks like you have two outputs connected together-PIR to 555 pin 3. 10k would be about right.
  9. mbohuntr
    Apr 6, 2009
    413
    32
    You are absolutely right! I should have wrote a 2 instead. The end of a long day. How did you guys calculate that value??
