Hi all, I am looking to add a motion sensing circuit to a CRT clock that I recently built. I would like the sensor disconnect one of the cathode ray tube's heater wires when motion is no longer detected after 10-15 minutes in order to prolong the life of the tube. (the CRT heater is 6.3v.). I am thinking a PIR module and 555 timer that would trigger a relay to "open" the heater wire. I have 12v. dc. going to a part of the clock that I can tap into, so I would probably also need to use a voltage regulator in the circuit. I am pretty adept at reading schematics and soldering, but don't have the knowledge to put all this together in a workable circuit. Does anyone have a similar schematic? Thanks for any help!
