I hadn't heard of this.
http://www.waterworld.com/articles/...-light-for-red-dead-sea-pipeline-project.html
That's a good point. Any calculations about how long this will work before the Dead Sea isn't far enough below sea level to make this work?The pumps are needed for de-salting and supplying water to a couple of million Jordanians. The fall to the Dead Sea will generate power.
Plus, all that extra water from the Med will probably decrease its salt concentration... probably making it more hospitable for life.... It's alive!... ALIVE!!!That's a good point. Any calculations about how long this will work before the Dead Sea isn't far enough below sea level to make this work?
Given the huge volume and surface area and overall hot dry climate natural evaporation plus local additional usages that will likely arise once it does start refilling I have doubts that it will ever fill up too far.That's a good point. Any calculations about how long this will work before the Dead Sea isn't far enough below sea level to make this work?
The fall of what - the sewage after the Jordanians use the fresh water?The pumps are needed for de-salting and supplying water to a couple of million Jordanians. The fall to the Dead Sea will generate power.
The Med would be closer but force stronger than money is forcing them to a more expensive option - the Red Sea.Plus, all that extra water from the Med will probably decrease its salt concentration... probably making it more hospitable for life.... It's alive!... ALIVE!!!
Gotta mitigate AGW-caused sea level rise somehow, no?Grand designs: the multinational proposal is to build a 180-kilometre pipeline engineered to carry up to two billion cubic metres of seawater per year from the Gulf of Aqaba on the Red Sea through Jordanian territory to the Red Sea. Why not cut out the middle man? Why do you need a pipeline through Jordan to move water from the Red Sea to the Red Sea?
Thread starter | Similar threads | Forum | Replies | Date |
Colonial Pipeline Paid Hackers Nearly $5 Million in Ransom | Off-Topic | 70 | ||
Y | pipeline ADC power consumption question | Analog & Mixed-Signal Design | 0 | |
Y | switching logic for 2.5bit pipeline ADC | Analog & Mixed-Signal Design | 0 | |
C | Question about Pipeline Cycle | Homework Help | 0 | |
F | Pipeline of MIPS processor | Digital Design | 14 |
