pinout of HEF4013BP and CD4013
Discussion in 'The Projects Forum' started by david1234, Jun 8, 2014.
  1. david1234
    Nov 27, 2013
    81
    Hello
    I'm having trouble with the pinout of HEF4013BP Vs. CD4013
    am I using it the same? or do I need to change something?
    CD4013
    1- ClR\
    2 - Data
    3- CLK
    4 - PRE\
    5 - Q
    6 - Q\
    7 -GND
    14 -VCC
    HEF4013B (http://www.nxp.com/documents/data_sheet/HEF4013B.pdf)
    1-Q
    2-Q\
    3-CLK
    4-PRE
    5-Data
    6-SD
    7-GND
    14-VCC
    can someone show me how to use this the HEF in this circuit?
    I'm afraid I will connect it wrong and "burn" the IC
  2. Experimentonomen
    Member
    Feb 16, 2011
    331
    46
    The pinout is the same.
  3. ericgibbs
    Jan 29, 2010
    2,604
    396
    hi David,
    Where did you get the CD4013 pin out data.?
    E
  4. david1234
    Nov 27, 2013
    81
    the Pinout - someone here help me with this circuit ,so I assume it's the correct one
    so maybe my problem is in the Transistor?
    my shop didn't have the FDC638P
    and I got instead Motorola 9648 EBCK
    is my reading of this part pin correct?
