Pinball machine power supply problem
Discussion in 'The Projects Forum' started by wraith644, Dec 15, 2010.
  1. wraith644
    Dec 15, 2010
    I am working on a gottlieb sys 1 power board for a friends pinball machine. When the power is turned on two of the diodes (CR3 and CR4)burn up. The input voltages are reading high. pins 1 and 2 are 12.7v instead of 11.5v, pin 3 is ground, pins 4 and 5 are 15.4v instead of 14v, and pins 6 and 7 are 75v instead of 69v. Voltages on pins 1, 2, 4, and 5 were taken from ground and pins 6 and 7 across the pins. I was wandering if these voltage differences would fry the board or are they within tolerance. I know that there is probably something else wrong with the board, but I haven't gotten that far yet. I'm trying to remember everything I learned about 16 years ago. It's amazing what you forget if you don't use it. Any suggestions will be greatly appreciated.
  2. #12
    Nov 30, 2010
    16,705
    7,358
    You will have to post a schematic before we can tell what you're talking about.
    wraith644 likes this.
  3. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    It would be very helpful to have a schematic to look at.
  4. wraith644
    Dec 15, 2010
    Ok, This is a schematic that i found online. http://tuukan.fliput.net/power.gif It is very close to the board. the only differences is that C9 and C10 are not on the board an C1 is a 4700uf 35vdc cap instead of the 2900uf 30vdc cap. I'm mapping the actual board myself, but that takes alittle time. I have also found out that lic1 is a LM7912 -12v regulator if that helps.
  5. #12
    Nov 30, 2010
    16,705
    7,358
    Start by suspecting C4 as shorted. Then check the 7912 to see if it is passing excessive current to some shorted load.
    There's a start. Check back if you need to.
  6. wraith644
    Dec 15, 2010
    C4 is not showing as being shorted. However, as I was removeing the mounting bracket, which aslo serves as a heat sink for Q1, Q2, and LIC1, I noticed there was no mica under LIC1 and Q2. It looks as if there was mica there at one time but is gone now. I checked to see if there was a conection between them and found out that pin 3 on LIC1 and pin C on Q2 were conecting throught the mounting bracket. I think this could be at least be a part of the problem.
  7. n1ist
    Mar 8, 2009
    171
    16
    Make sure the tab of the 7912 isn't accidentally grounded; the pinouts are different between the 78xx and 79xx family.
    /mike
  8. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    SCR201 is part of a crowbar circuit. Something may be tripping it. This might be a case where loading the 14 VAC lines down with a couple of automotive lamps to prevent the voltage from coming all the way up could be useful. If the caps check, then something is going on with the crowbar - the SCR could be shorted.
  9. rushfan
    Jan 8, 2012
    hi
    new to this posting business... just wondering if you managed to fix the power supply? Im having the same issue with cr3 and 4 burning... thanks
