Pinball Machine... driving me crazy
Dalaran
Joined Dec 3, 2009
168
I have quite a strange problem with my pinball machine project. Please see the 2 links below for the power wiring/supply board schematics of my system.
Power Wiring Schematic
Power Supply Board Schematic
With nothing connected to the secondary of the transformer I draw ~450mA, which seems reasonable to me. With all fuses unplugged it only takes hooking up 3J1-12 to the power supply board and I draw 4A. This is a ground pin (center-tap of 2 x 9.3VAC) and I am getting crazy current consumption.
Originally the machine came to me with a cooked transformer, and I had recently replaced it. I'm guessing whatever caused the last one to go will soon take its toll on this one. Any ideas what might be happening? I am completely lost.
Thanks.
retched
Joined Dec 5, 2009
5,208
All fuses removed and current draw on the ground leg?
Have you tried a continuity test on all fuse holders with power off, to check for possible shorts?
Im trying to follow the schematic and run into fuses..
If one of the transistors have failed shorted, you could be getting feedback, but it would require a return to hot :rolleyes: ...via a fuse...
hmmph..
Solder bridge?
Dalaran
Joined Dec 3, 2009
168
Thanks. Same thoughts I was having. I do not have any shorts between any of the pins on 3J1 (except the grounds as expected) and all seems normal. I removed the power supply board and all looks good. Only one capacitor seems to have been replaced, the solder job is not pretty but there is nothing to bridge it too close by. This is why I am shaking my head. Just not even sure where to keep looking.
I guess this means however that somewhere on my ground (runs throughout the entire machine) I must have a short to hot? Possibly only manifests itself with the power on? As I mentioned, power off, I do not see anything unnormal on either the supply board or power wiring.
Thanks for your time.
edit: I am thinking of removing the ground from where the mains plug comes in and connect it directly to 3J1-12. This way there is nothing else on this ground connection so ideally I won't see this large current draw. Then I can work from here. Thoughts?
Dalaran
Joined Dec 3, 2009
168
Thanks for the reply. 10J1 is disconnected. I have also lifted the anode leg of both diodes D7 and D8. I checked C15 for sanity reasons and it is not shorted.
All other help is appreciated.
Thanks all.
