I tested at CR26 and on both boards +5.08The +5v supply voltage is the same on both, right?
On both boards I get +0.6v.Measure the voltage across CR26. On the good board, you'll get around 0.7v; on the bad board, about 1.4v.
Yes, I replaced C23 and CR26 and CR37.Did you ever replace C23? You said you were going to, but never said you actually did so yet.
Voltage did drop across R133 to zero.See if there is a voltage drop across R133. If zero, then OK. If >0, then something in the battery holder is shorting. Removing R133 or lifting one end of it will remove that problem.
Agreed but on the board its different (see pics) maybe internal in Z2?The schematic shows pins 3, 5 and 16 all connected directly to each other by wire/traces. I missed that before when you reported the voltages; I just looked at the lower voltages and completely glossed over pin 16.
No, it wouldn't have shown the pins wired together then.Agreed but on the board its different (see pics) maybe internal in Z2?
Yes. With the power off, you might measure how many Ohms resistance you get from pin 3 to pin 16 before you solder a jumper in there. Like Gerty wrote, the trace is hidden under Z2's IC socket. Don't try to unsolder the socket; they're kinda tough to get out without messing things up.Since the schematic shows Pin3, 5 and 16 at the same voltage for a test could I jumper Pin16 to Pin3 on the bottom of the board?
A tad "iffy" - but it's hard to tell in a photo. Make certain that you have cleaned the area/components to be soldered with 90% or better isopropyl alcohol and an acid brush (you can get acid brushes at auto parts stores), use rosin flux, 93/37 solder, and a soldering iron of the proper temp that has a clean and well-tinned tip. Be certain to clean residue off afterward.I'm sure you've seen lots of solder jobs I hope mine passes the mustard...
What values did you use for R159? Were you careful to clean any flux off of them? Flux has a pretty high resistance, but it isn't infinite.I've ordered another Z2 and a couple of resistors that I didn't have mainly R159 that I had to solder a couple of resistors together to get the correct resistance for.
Gerty, good point I'll pull the chip and look.The 3-16 jumper is probably under the IC, on the component side.
I'll post when I get back to the house the values of R159.What values did you use for R159? Were you careful to clean any flux off of them? Flux has a pretty high resistance, but it isn't infinite.
I suggest that you DON'T pull Z2 unless you really have to. Those machine sockets tend to tear the legs off your ICs when you try to remove them. You can simply measure the resistance from pin 16 (+ probe) to pin 3 (- probe) and see what it is. If you get anything higher than 1 Ohm, you'll need to solder a jumper from pin 16 to pin 3 on the bottom.Gerty, good point I'll pull the chip and look.
It is powering up on the bench. I have a feeling I might run into some other in game issues but you've been a great help in tackling the reset issue.Funny, I was thinking earlier that you might've nicked the trace inserting a screwdriver under the IC to pry it out.
Don't worry about the Pin 2 increase at the moment.
Is the board working now?
by Duane Benson
by Dale Wilson
by Aaron Carman
by Jake Hertz
