Hi
I need help with a circuit I am making for work. I need to be able to view on one channel on the scope a multiple solenoid driver signal. They are activated sequentially. They are supplied with a common 12V and driven by separate drivers in a computer which grounds each at a given time.
So the signal from one of the solenoids driver side would be 12v to ground and when the ground opened, it gives an inductive kick hick to say 80v. I want to view all the drivers signals on one scope channel.
Many thanks
Many thanks
