Hi everyone this is my first time posting here, and happy to talk with like minded people.
my question is, how would one piggy back a low voltage albeit high amp power supply onto a high voltage low amp circuit.
im using a 555timer circuit to control a 12vdc relay which, in its normally closed position is fed 110vac 3amps from an inverter connected to a car battery.
From the inverter it goes to a half wave voltage doubler, the output dc chargers a 300volt 80uf capacitor. When the relay switches from NC to NO, it then dumps the charge from the capacitor to a Blaster MSD II 45k ignition coil +/- terminals.
the HV out and ground on the ignition coil are are connected to two seperate 12gauge solid copper wires forming a spark gap.
NOW HERE IS THE PROBLEM.
When i reduce the distance of the spark gap to 2mm, and place water droplet in between the two wires and dump the capacitor load into the ignition coil. All that happens is....NOTHING. even adding an electrolyte does not a thing. I can achieve an 1.5 1.75in spark with the gap open.
How do I gain about 10amps or more, so there is current to push through the water effectively blasting it apart?
what if i connected a car batteries + to the high voltage line coming out of the ignition coil and - terminal to the negative terminal of the ignition coil.
would this be effective, essentially there would be 12volts and the current of the car battery just sitting waiting for the high voltage burst to travel down so the high current can ride a long the high voltage?
or am i completely wrong, and ideas!?
