hey frnds i am planning to prepare a piezoelectric mat that will convert the human movement into electrcty and hence need some guidance for it.....
thanks in advance.....
hey bmorse just read abt that IC but want to ask will it work in my application where i will be converting human kinetic energy into electricty and if yes how and where shall i use this IC.
P.S.The LTC3588-1 integrates a low-loss full-wave bridge rectifier with a high efficiency buck converter to form a complete energy harvesting solution optimized for high output impedance energy sources such as piezoelectric transducers. An ultralow quiescent current undervoltage lockout (UVLO) mode with a wide hysteresis window allows charge to accumulate on an input capacitor until the buck converter can efficiently transfer a portion of the stored charge to the output. In regulation, the LTC3588-1 enters a sleep state in which both input and output quiescent currents are minimal. The buck converter turns on and off as needed to maintain regulation.
Lucky, I feel privileged to have a small drill press both at home and at work.I also have access to a CNC laser, and I have a CNC Plasma Cutter at the shop too, so I can pretty much mill, engrave, cut anything I want, the CNC Plasma can cut upto 1" thick steel
B. Morse
hey can you just post me the image of your sample of LTC ic as i have just orderd it and it will take some time so i just want to know its size and how you will be using it in ur setup.......
REGARDS....
Thread starter | Similar threads | Forum | Replies | Date |
Piezoelectricity | General Electronics Chat | 2 | ||
Piezoelectricity generator for mobile charging | General Electronics Chat | 10 | ||
A | piezoelectricity | General Electronics Chat | 0 |
