Piezoelectric Transducer Trigger/sensor project
Discussion in 'The Projects Forum' started by nikoTesla, Aug 24, 2014.
  1. nikoTesla
    Aug 24, 2014
    Hi, I'm a physics student from Nigeria and I'm interested in doing a project involving piezoelectric transducers.
    The project will deal with how a piezoelectric material can produce voltage from the mechanical stress of a human footstep,
    so my first question would be how and where can I find (buy) a piezoelectric transducer (plate) that can withstand the weight
    of a footstep and is not so sensitive to vibration that any little disturbance will produce voltage. Or how can I dampen the
    voltage response produced from ordinary vibrations/sounds/disturbances?
    Please suggest which of the following products on Aliexpress.com will be best suitable for this purpose (that's basically
    the only place I can easily get these piezoelectric materials shipped to Nigeria)
    http://www.aliexpress.com/item/High...c-Transducer-Cleaner-45mm-Dia/1740089597.html
    http://www.aliexpress.com/item/Genu...ceramic-humidifier-accessories/907653251.html
    http://www.aliexpress.com/item/Free...c-chip-piezoelectric-ceramics/1981491165.html
    http://www.aliexpress.com/item/Ultr...ric-ceramic-ultrasonic-sensor/1758147590.html
    http://www.aliexpress.com/item/5pcs...ent-Ceramic-Ring-freeshipping/1353867677.html
    If none of these piezoelectric products can do the job, can you please suggest where I can get the right materials.
    Secondly, I need the piezoelectric transducer to act as a sort of trigger/sensor such that the voltage is maintained for as long
    as the foot is on the device, as soon as the foot is removed, the voltage should be cut-off. Can the circuit described in this
    thread (using IC 555) be used for this specific purpose?
    http://forum.allaboutcircuits.com/showthread.php?t=80497
    Can you give me any TESTED circuit where a piezo trigger (or sensor) is made to produce constant voltage when pressed (or strained
    in one direction) and voltage is cut-off when pressure is released.
    Will be expecting your informative replies. Thanks.
  2. zyklag2005
    Apr 6, 2012
    Hey,
    This seems to be the one piezoelectric material suitable for such a application. But i do not know if they will ship to Nigeria. But maybe you can get someone to buy and send it to you.
    http://www.faceinternational.com/
    Goodluck.
  3. Bernard
    Aug 7, 2008
    4,240
    414
    A piezeo disc will not maintain a voltage but when flexed in one direction will produce a + pulse, when reversed, produces a - pulse. Using a piezeo speaker element, 2 cm dia disc, maybe like second ref, /Genu/ , made a sandwich of 1/8 cork sheet; cork , disc, cork, 1/2 plywood top cover. On stepping on it, a 30 V neg. pulse, 40 ms fall tine 60 ms recovery; on release, 25 V + pulse produced with same rise & fall times. About 5 V P-P noise present.
    To detect, I think comparators would work by biasing one disc to about 9 V to det. _ pulses, other set to det. + pulses. Arrange outputs so that pressure produces a neg. pulse to trigger a 555; release of pressure to reset 555.
  4. Sensacell
    Jun 19, 2012
    1,184
    277
    I made a simple 12" square "footstep sensing plate" by attaching the piezo disk from a large beeper to a piece of 1/2" acrylic with some double faced tape.
    The output went to a simple high impedance amp. it worked pretty well considering the simplicity.
    The key is mounting the disk with a semi flexible adhesive, to control the stress on the piezo disk. I mounted the sensor underneath in the center.
    Support the edges of the plastic, so it flexes from the load.
