I am looking for piezo transducers with the following specs:
Resonance frequency 10.5khz
Resonant Resistance: 400 Ω
Capacitance 12,000pF@100Hz
Disc diameter:~15mm
I do not have much of an electrical background therefore, I have been having trouble locating those type specs. I have found however, these on eBay:
Resonant Frequency: 6.8 ±0.7kHz
Resonant Resistance: 300Ω Max
Capacitance: 15,000pF ±30%
Disc diameter: 20mm
Also, I found a guy that sells some with the following specs:
Resonant Frequency: 6.5kHz Resonant Resistance: 500 Ω
Capacitance: 14,000pF
External Diameter: 20mm
What do you think, folks ? I'd like to find specs that match the first transducer. If the specs are close, can they be easily tweaked ? Thanks a lot guy ?
Bret
Disc diameter:~15mm
Disc diameter: 20mm
Bret
