Piezo Transducer JFET Buffer
EMFELAB
Joined Feb 11, 2013
10
I need to interface a Piezoelectric transducer sensor which will pick up frequencies up to 1000Hz. It was advised to me to use a JFET source follower circuit. The piezo transducer is simulated here as a AC source in series with a capacitor (10nF), as I understand the Piezo needs a very high input impedance so I haven't connected a RG across the input of the JFET since that would effectively bring down the input impedance of the circuit.
When simulating this circuit, the output gives me 0V and I assume that the biasing is not right; placing a resistor across the gate brings down the signal to 0V DC but the output is still 0V. Now, if I get rid of C3 and R2 and I measure from the source, I get a signal with lower amplitude than the input and with a DC offset. Any suggestions??
Ramussons
Joined May 3, 2013
1,414
We are all blinded without a schematic.
Ramesh
30,824
Change your circuit design to a common source circuit.
You will need three resistors, one for the drain, source, and gate.
30,824
Note that your PN4392 is an N-channel depletion mode FET.
There are four combinations, P-channel vs N-channel and depletion mode vs enhancement mode.
For depletion mode, you need to bias the gate -ve with respect to the source in order to pinch off the channel. You do this with a resistor from the source to ground. You can add a 10MΩ resistor from the gate to ground to give the gate a reference voltage of 0V.
DickCappels
Joined Aug 21, 2008
10,187
If you just want an approximately unity-gain buffer, the circuit you already have should work fine, EXCEPT...you need to put a 1 meg to 10 meg resistor from the gate to ground so that the source voltage and be used to provide negative feedback to establish the FET's operation point.
EMFELAB
Joined Feb 11, 2013
10
Mr Chip. I do not want a common source configuration, a source follower will do as I need a very high impedance. The simulation will not work if I do not bias the gate properly and this means having a gate resistor in parallel.
At the beginning I did not want to do it since it would mean having a resistor parallel to the very high input resistance of the JFET and so lowering it. Therefore, as I understand, the input impedance is simply RG.
