If you pinch the special JFET out of an electret MIC capsule and hook it up to my TL431 booster circuit - a piezo disc could well be *TOO* sensitive.Quick question: I want to make some drum triggers(using and arduino board for processing) and I was wondering if the diameter of a piezo sensor has any direct relation to sensitivity?
One question can be many methods to solve it, show your circuit, I will test it ...If you pinch the special JFET out of an electret MIC capsule and hook it up to my TL431 booster circuit - a piezo disc could well be *TOO* sensitive.
Hook up the TL431 with a Vcc supply and bias it so it drops half the Vcc across the load resistor - that will put exactly 2.5V on the control/input pin, which is just about right for the JFET. That alone may be sensitive enough, but you can get *MASSIVE* gain by splitting the feedback resistor in 2 and AC grounding the tap between the 2, that gives you loads of DC nfb to stabilise the operating point, but no AC nfb to reduce the gain.
It was published in Elektor magazine a couple of years ago.One question can be many methods to solve it, show your circuit, I will test it ...
That looks pretty much copied from my article in Elektor.
So, you want to use the microphone to replace the piezo?That looks pretty much copied from my article in Elektor.
You could have tried bothering to read what I said:So, you want to use the microphone to replace the piezo?
I had been designed the microphone to control relay as on/off toggle switch.
