R3 prevents the Gate from floating. C3 is a good idea to suppress false triggering and suppress transients and noise.I have a few questions about your circuit.
R3 and C3, what are their function?
Off hand I'm inclined to say no but I will have to spice it and get back to you. For certain... not the way you drew it!!Do I need to feed the signal from the piezo though Q1, isnt the current comming from the piezo enough to trigger the 555 timer? (the way I drawed it?).
Yes, but change C1 to ~4 to 5uF. Note!: R1 must remain. You can change its value but it should not (practically) be below 1K.Can I change the potentiometer to 1 meg ohm (that what I bought for the other circuit, and it could be nice if that would fit).
Depends.. Is your supply still 6V as it was when you started this thread?Can I use a 220 ohm resistor infront of the LED as in the other circuit?
YesDo I have to put a capacitor to the control pin?
A 555 triggers when the Trigger pin goes low, or more specifically, on its negative going edge. So... Sgt.Wookie's circuit rectifies the AC output of the Piezo, clamps the positive going signal at 15V with the Zener, and filters the signal a bit with the Gate Cap. This voltage is applied to the Gate of the FET which turns on the Drain - Source junction of the FET. This causes current to flow through R2 because current is now flowing between the Source and the Drain. Since a Common Source Amplifier inverts its output at the Drian, this will produce a negative going edge to trigger the 555.Can you tell me what function R2 has? I havnt drawned that on my drawing, so I am currious. If I had to guess, I would say it is there to limit the current from both the piezo and the power supply to keep the current below the 15 volt the 555 timer can handle?
That's a typo. That should read .01uF (10nF) but it's not a critical value. A .01uF to .1uF will work fine.C2, is that a 10 microfarad or what does m stand for?
Since you have a 1Meg pot already refer to the schematic in post 27. This is the circuit I'm basing the following on and the one you should build.Thanks very much for the new drawing. That somehow looks more confusing, than the one with the mosfet in it.
Just to be absolutly sure, that I have the right parts. The other drawing you did with the mosfet in it, is this true:
C1 = 10uF
C2 = 10nF
C3 = 1nF
Is C3 also not so critical and would a 10nF capacitor be alright to use insteed? Does R3 have to be 1 meg ohm? I will go and buy some if needed, but if I can use anything else on hand that would be prefered.
That's what was done in this circuit.If I put an amplifier before the 2N7000 mosfet, it would kick the low voltage comming from the piezo up, so it would be enough to trigger the 2N7000 and with it, the whole circuit, right? If I put a potentiometer in the amplifier circuit bit, then wouldnt I be able to control the sensitivity of the circuit to some extend?
Thread starter | Similar threads | Forum | Replies | Date |
M | How to solder wire on Piezo Disc? | Sensor Design & Implementation | 4 | |
Piezo pulse of 0.5v to trigger a switch | Analog & Mixed-Signal Design | 2 | ||
How to drive a piezo disc | Test & Measurement | 3 | ||
R | Piezo to toggle LED light | General Electronics Chat | 21 | |
Piezo-electric light bulb repair | General Electronics Chat | 5 |
