Why not start closer to the solution?Hi everyone..
May someone help me in PID simple code ?
thank you "tshuck"..You seem to have some uncertainty in your understanding.
PID uses the error to determine what value should be applied to the controlled device(plant) to make the input minus the feedback quantity equal to zero (indicating the controlled parameter is at the commanded input).
A PID controller uses the error (current error, rate of change of the error[derivative], and accumulated error[integral]) multiplied by some constant values(\(k_p\), \(k_i\), & \(k_d\)) to determine the output parameter. In tuning a PID, one selects the \(k_p\), \(k_i\), & \(k_d\) & to accomplish the controller requirements (e.g. rise time, overshoot, response type, etc.)
In digital systems, the derivative is no more than the difference between the current error and the previous error, where the integral is the current error added to previous errors.
thank you " crutschow " . this is my project definition that I have to use PID control method , by the way I'm interested in FUZZY control too.. do you have any inrtoduction file ?You might consider a type of control loop that doesn't require calculation of the integral or differential of the signal as PID does which is Fuzzy Logic. It basically consists of a series of If-Then-Else loops to control the system. This can be more intuitive to write in computer code than a PID loop and can be more tolerant of system non-linearities.
thank you " THE_RB " ..Why not start closer to the solution?
WHAT do you need to control?
Click on Fuzzy Logic in my original post. Also Google Fuzzy Logic.thank you " crutschow " . this is my project definition that I have to use PID control method , by the way I'm interested in FUZZY control too.. do you have any inrtoduction file ?
Do you have the time constant of the furnace? ie; how many seconds it takes, for the temperature to rise 1 degree C?thank you " THE_RB " ..
I have to control the Temp. of a furnace which is warm up by TEC plates!
