PID discretization using different methods
Discussion in 'Homework Help' started by christin003, Feb 27, 2013.
  1. christin003
    Feb 20, 2013
    I am using simpson's discretization to change the continuous PI to the discrete PI however it results in three poles and one of them is unstable. Did you have any issues when you were discretizing? Also did you use 3/8 rule, with that I have the controller when simplified as a third order controller. Is that correct?
  2. tshuck
    Oct 18, 2012
    3,531
    675
    To be clear, since the OP didn't, this thread is referring to this other one, otherwise it's just a question to no one...
    One way to tell is to do an analysis on the system, determine its response.... that usually how a controller is verified:rolleyes:
