PID control
Discussion in 'General Electronics Chat' started by TAKYMOUNIR, Mar 14, 2013.
  1. TAKYMOUNIR
    Thread Starter Active Member
    Jun 23, 2008
    351
    please I need help to understand how to design voltage control loop or current control loop in PID control for designing high voltage power supply
    is someone know good links or lectures for this subject
    thanks
  2. antonv
    Member
    Nov 27, 2012
    149
    27
  3. TAKYMOUNIR
    Jun 23, 2008
    351
  4. Markd77
    Sep 7, 2009
    2,803
    594
    One of the best descriptions I've seen is on the Wikipedia page.
    If any of the terms are too large there will be too much overshoot and maybe oscillation. Too small and the speed of response is not as good as it could be.
    TAKYMOUNIR likes this.
  5. crutschow
    Mar 14, 2008
    13,466
    3,353
    Here's a good reference on designing stable control loops in switching power supplies.
  6. Jaguarjoe
    Apr 7, 2010
    770
    90
    You are driving a car on a flat level road. With the throttle at a random fixed position, the car will travel at a fixed speed, typically different from the set point (the speed limit sign) because the load is constant.
    When you climb a hill, without moving the throttle, you will fall far away from the set point because the load changed.
    Proportional only control is driving on that flat level road. You will only run at one speed and cannot react to any change in load.
    Reset or Integral integrates the difference between your speed and the set point forcing the throttle to make your speed equal to the set point.
    Preact or Rate or Derivative will begin to work at the inflection point of the hill you were climbing maintaining the setpoint before any significant deviation occurs.
  7. TAKYMOUNIR
    Jun 23, 2008
    351
    Hi can you please help me i submit thread about ac signal in differential amplifier can you help me in this
    thanks
