PicStart Plus USB
Discussion in 'Embedded Systems and Microcontrollers' started by jpanhalt, Mar 13, 2009.
  1. jpanhalt
    Thread Starter AAC Fanatic!
    Jan 18, 2008
    5,699
    909
    Does anyone know whether the PicStart Plus will work with a serial-to-USB adapter?
    I would prefer that solution, rather than an internal serial card. The adapters at my local store are relatively expensive ($30 or more), which is more than I want to spend just to find out.
    Thanks. John
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    The use of USB-to-serial adapters is mentioned on page 70 of the MPLab Picstart Plus User's Guide:
    http://ww1.microchip.com/downloads/en/DeviceDoc/51028f.pdf
    If the USB-to-serial adapter needs 3rd-party drivers, it might not work.
    You might search/post on the Microchip forums; see if anyone has had success with that using your particular O/S with a given vendor's adapter.
  3. jpanhalt
    Jan 18, 2008
    5,699
    909
    Thanks. You must have a great memory. It's been 4 years since I looked at the PicStart manual. I will try to remember that detail for the future.
    I have been collecting parts for my new PC over the past week or so. Started assembling it today and got a pleasant surprise. The MB has a serial socket on it. All I need to do is run the cable link to the back panel. Don't need to use one of the expansion slots. Will need to use one though for my parallel-only vinyl cutter (Roland/Dr. Stika).
    John
  4. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Re: good memory
    Well, I confess that I'd never looked at the Picstart Plus manual before your inquiry, but I'm pretty good at finding manuals and digging out what I need from them ;)
    Good news on the mobo serial sockets - but when you're finally configuring the ports, make sure that the IRQs aren't shared with something else. If your mobo has legacy ISA/PCI settings for IRQ assignments, you'll probably have to use them.
    The old standard was that COM1/COM3 shared IRQ4, and COM2/COM4 shared IRQ3. Most older PC's only have COM1 and COM2, but if you added an internal modem, it would "want" to go to COM3. This messed up my interface with my UPS communications, as there was an IRQ conflict. I wound up resolving it by manually configuring the modem to COM2/IRQ3, and re-assigning the mobo COM2 to COM3/IRQ4. As long as COM1 and COM3 weren't open at the same time, there wasn't a conflict.
    If you just use "plug and pray", you are likely to wind up with problems.
  5. Wotty
    Dec 21, 2010
    Hi there,
    There are some (Very Very few and old) USB to Serial adaptors that don't work with PICSTART Plus
    There are one or two that work but hang very frequently, I had one and in the end threw it away.
    Modern ones work fine but you need to set Picstart to find them
    1) Install the drivers for the USB to serial adapter using the disk supplied, DON'T let windows do it itself
    2) Plug in the adapter and PICSTART Plus
    3) go to control panel/system/Device manager look in Ports (Com &LPT) and you'll find the USB to serial device, it'll be COM5 or COM8 or somesuch number.
    If you can't see device manager
    go to folder options and (in Appearance and Personalization for Windows 7) click the view tab and enable show hidden files and disable hide protected...
    4) Now open MPLAB
    Select Programmer PICSTART Plus
    Settings
    Communications
    then enter the COM port number you obtained from step 3
    Hope this helps,
    Wotty
  6. CDRIVE
    Jul 1, 2008
    2,223
    99
    I probably own more USB/Serial converters than most. Six at last count. All of them came with their own drivers and none of them has ever given me a lick of trouble, with the exception of one issue with my Belkin model. The issue is 'Break Mode', which isn't used much any longer in serial communication but my Picaxe Interpreter/Compiler uses it when it's programming the chips. The only other issue, that all converters have, is related only to my VB6 MSComm's 'OutBufferCount' property, which can't be reliably returned from a virtual CommPort.
    FYI, all the control and data pins on a USB/Serial converter output + & - 5V. as apposed to the + & - 15V standard of a physical serial port. I have used converters in NullModem configurations between two USB ports, Converter to true RS232 and to my microcontrollers.
    When interfacing to the 5V serial I/O of the Picaxe I don't employ a Max232, I just insure (with a 1N914) that the chip doesn't see -5V.
    To sum it up.. I like them and I'm thankful they exist.
  7. jpanhalt
    Jan 18, 2008
    5,699
    909
    I just noticed this was a thread started by me quite awhile ago. I got the opportunity to compare the serial adapter/port provided on the mobo of an Asus with an aftermarket USB adapter. The Asus adapter did not work with my PicStart Plus. A common aftermarket USB to serial adapter did.
    John
  8. CDRIVE
    Jul 1, 2008
    2,223
    99
    Uggghhh! I hate when I do this. I really, really.....really gotta start check'n the post dates!!
