Hello, need some help please? I was wondering if I can substitute a 1A pico fuse for a 2A pico fuse or for a 0 Ohm resistor?
The reason is that I can't find a 1A pico fuse and the guys at the store told me I could use the 0 Ohm resistor instead. If you had to decide between both wich would you use?
