Pickit3 can't detect PIC24FJ128GA310, Error "ensure proper capacitance on vddcore vcap pin"
Discussion in 'Embedded Systems and Microcontrollers' started by yassyou, Jul 4, 2016.
  1. yassyou
    Feb 11, 2016
    Pleas I need help about connection between Pickit3 and PIC24FJ128GA310. So I can programme it .
    I'v followed the circuit in the picture attached . but I keep get the Error : "ensure proper capacitance on vddcore vcap pin" in the Pickit interface.
    Thankyou for your help
  2. ErnieM
    Apr 24, 2011
    7,447
    1,628
    ALL the Vdd pins need to be connected together and all need those caps.
    ALL the Vss pins also need be connected together.
  3. yassyou
    Feb 11, 2016
    First thankyou,
    Acually all the Vdds and The Vss are connected internally ,
    and I did conected theme All to the caps , I've mention it int circuit picture attached
    but I keep get the same error
  4. dannyf
    Sep 13, 2015
    2,196
    417
    read the datasheet - there is a whole section on that.
  5. NorthGuy
    Jun 28, 2014
    611
    121
    Is it stand-alone PICKit programmer? I though Microchip stopped supporting it since long time ago. It says "insupported part". You need to select the exact device. There are lots of different PIC24 parts which are not compatible with each other.
    PICkit3 cannot tell if VCap is connected or not. It can only know that the communication has failed, which is usually a bad connection. However. using the software with unsupported PIC device will produce the same effect.
  6. DickCappels
    Aug 21, 2008
    2,792
    678
    There might be a problem with trace length or grounding. Please post a photo of your breadboard/prototype.
  7. Picbuster
    Member
    Dec 2, 2013
    391
    53
    Pin 85 needs 10uf + 100nf parallel this allows the cpu to run.
    next thing is to check power sours pickit 3 or your pwr supply or both.
    Picbuster
