pickit2
Discussion in 'General Electronics Chat' started by ddickey, Feb 8, 2012.
  1. ddickey
    Sep 28, 2011
    55
    Will a pickit2 work w/a pic16f628?
  2. Markd77
    Sep 7, 2009
    2,803
    594
  3. ddickey
    Sep 28, 2011
    55
    I can't get it to work. It says no device found.
  4. spinnaker
    Oct 29, 2009
    5,102
    1,190
    Do you have power to the device?
    Have you confirmed your ICSP connections are correct?
    Post your schematic.
  5. ddickey
    Sep 28, 2011
    55
    Yes it has power. it's a 16f628 chip. I have a hex file i'm trying to program the chip with. If i change the device family to baseline and click 16f526 I cna do a partial download then i ge an error which i was suspecting anyway.
  6. spinnaker
    Oct 29, 2009
    5,102
    1,190
    Are you using MPLAb?
    I am showing the 16f628 as red (not supported) by MPLAb and PicKit II, all other Microchip programmers support it.
  7. ddickey
    Sep 28, 2011
    55
    Ok, I got to detect. WHen i try to program it says "programming failed at program memory adress 0x00000"
  8. spinnaker
    Oct 29, 2009
    5,102
    1,190
    See my post above.
  9. ddickey
    Sep 28, 2011
    55
    Yes. mplab. SO does that mean i need a pickit3 then?
  10. PaulEE
    Member
    Dec 23, 2011
    423
    32
    If you use the standalone program that the pickit2 ships with, you can flash the pic that way. 16f628 should be auto-detected under 'midrange-->standard' in that small app.
  11. spinnaker
    Oct 29, 2009
    5,102
    1,190
    Yes according to what I am seeing.
    Or get a Pic that is supported by the PicKit II.
    Strange page 121 of the datasheet does not list the PicKit 3 either only
    Device Programmers
    - PRO MATE® II Universal Device Programmer
    - PICSTART® Plus Development Programmer
  12. PaulEE
    Member
    Dec 23, 2011
    423
    32
    I have a 16F627 hooked up to the PICKIT2 on the mid-range - standard auto-detect setting; just read the memory. See picture below for pinout (datasheet wasn't much help for me). 16F627/8 share a datasheet, FYI.
    MCLR -> pin 4
    V+ -> pin 14
    V-/gnd-> pin 5
    PGD -> pin 13
    PGC -> pin 12
  13. spinnaker
    Oct 29, 2009
    5,102
    1,190
    I think the OP was trying to program with MPLab. Good to see that it works with stand alone programmer as you say. Strange it is not listed on the chips datahseet.
  14. PaulEE
    Member
    Dec 23, 2011
    423
    32
    The datasheet misled me. Usually, you see pins labeled "PGMD" and PGMC" or something along those lines. All I saw was "PGM" on pin 10. I actually goog'd it and found an image of someone else's breadboard to learn how to hook it up. After that, the standalone app was happy.
    As for MPLAB, it should work just the same. Maybe now that the OP has a wiring diagram (sort of) he/she can get it to work..?
    Let us know!
  15. ddickey
    Sep 28, 2011
    55
    Ok so I can't use the board that comes with teh programmer. I plug it onto my breadboard and hook it up that way, eh?
  16. PaulEE
    Member
    Dec 23, 2011
    423
    32
    OH! That explains it.
    No way, the 16F690 has a complete different pinout. If you breadboard it as I did, you should be fine.
  17. ddickey
    Sep 28, 2011
    55
    Ok I've got it wired onto my bread board. I must be trying to download an improper file as it load 130 lines then gives me the fail message again. I'm tryingto make this http://embedded-lab.com/blog/?p=1671 he posts the file a ways down in the article. I open the link and download teh hex file. I think I'm doing something wrong or maybe there is only 130 lines of data?
  18. t06afre
    May 11, 2009
    5,939
    1,222
  19. ddickey
    Sep 28, 2011
    55
    It is an 628a i guess. SO it will work ok even if the holde has 20 pins? Still not sure about programming it though.
  20. Markd77
    Sep 7, 2009
    2,803
    594
    That hex file is fine, I've just burned it to a PIC16F628A with my PICKIT2 with no errors. My setup is a little different to yours, I used a ZIF socket and pk2cmd software but it should make no difference.
