hello i just bought the PICKIT 2 programmer , but i dont know how to use it to program a muc, do i need to buy another component with the kit? or what do i really need to do......
Load the hex file and click "write" button...you also could use 'button' on the pickit2 to program your uC, but you have to enable this function first...
hope this will help.....
You're right...i am thinking that he knows all these issues before he bought the device.Actually it all depends on how you are using the Pickit2:
- Is the uc you are using a Microchip Pic?
- Are you using it as a standalone programmer??
- Or are you using it as a programmer / debugger in MPLAB??
- Does your uc support ICSP??
- Does the pickit2 support the uc you are using?
- Is your uc powered up?
- Is the uc in a circuit where the PG and PD I/O's have anything connected to them?
- Do you have Low Voltage programming enabled?
- etc.... etc.....
Providing a schematic of the uc's circuit could be helpfull, or atleast some more info on how you are trying to use... for all we know, you could be trying to program an AVR with it
But how about it. If there were a PICKIT clone that had six leads with female plugs that you could attach to the chip leads to apply power and program, outside of a circuit using ICSP.
-don't mean to confuse-
and thanks for the compliment, must have checked out my site, thanks....Vdd
During ICSP programming, the device needs to be powered in accordance with the device specification. Typically, the device supply voltage is connected to the application circuit supply voltage. The application circuit can be powered by the PICkit 2 or externally. There are a few precautions that need to be observed in the situations covered in the following three sections.
The application circuit is powered by the PICkit 2
The PICkit 2 supply voltage may set between the maximum and minimum voltages allowed by the device programming specification, unless the minimum is below +2.5V. Be sure to set the voltage box to the appropriate voltage before programming the device or turning on Vdd.
Check out this way to program AVR chips with the PICkit2 For my own part I will not try to go down that roadActually it all depends on how you are using the Pickit2:
Thread starter | Similar threads | Forum | Replies | Date |
P | PICKIT2 prolem | Microcontrollers | 8 | |
P | PICKIT2 and PICKIT3 doesn't wotk on My WIN10, but they work in XP, which is not connected ro Internet | Microcontrollers | 10 | |
P | PICKIT2 problem "Verification Fail" | Microcontrollers | 11 | |
Re tuning the Pickit2 | Microcontrollers | 23 | ||
M | PICKIT2 programmer help! | General Electronics Chat | 1 |
by Jake Hertz
by Jake Hertz
by Aaron Carman
