PICkit 2-Windows 64-bit Operating System
Discussion in 'Embedded Systems and Microcontrollers' started by lmartinez, Apr 17, 2009.
  1. lmartinez
    Thread Starter Active Member
    Mar 8, 2009
    224
    6
    Is the :)Pickit 2 software compatible with Windows Vista 64 bit Operating System. Please Advice
  2. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    It is compatible with 32-bit Vista, however AFAIK it is "not supported" on Vista x64 - what "not supported" means could be one of several things, whether it be that it just doesn't work or that its works but there is no tech support for any issues you may have.
    The IDE will probably install and work fine within x64 however your problem will be with any drivers you need.
    Might I advise that you contact an Applications Engineer at Microchip and see what they have to say about it; if it still isn't supported they may be able to offer you a work around and perhaps some "un-supported" components.
    Let us know how you go on, I'm sure others will be interested in knowing.
    Dave
  3. lmartinez
    Mar 8, 2009
    224
    6
    I bought me the laptop with Windows vista x64 as the operating system. I installed the Pickit 2 software, MPLAB IDE V8.30, and HI-Tech software. It appears to be working good. I did not have any issues with the installation.
