PICAXE 18X Question (relating to RC)
Discussion in 'Embedded Systems and Microcontrollers' started by NM2008, Jul 12, 2009.
  1. NM2008
    Thread Starter Senior Member
    Feb 9, 2008
    135
    Could somebody tell me is it possible to interface an RC reveiver to a PICAXE controller.
    What I am trying to do is,
    Take a pulse from a channel on the RC receiver,
    Send it to an input on the Picaxe,
    Have the varying 1ms to 2ms pulse trigger a program/code.
    Is this possible?
    For example when the TX stick is moved to transmit a 2ms pulse, the picaxe will pick up on the pulse changing from 1.5ms to 2ms then trigger a simple code to put an output on the Picaxe high.
    Any info on this would be greatly appreciated,
    Regards NM
  2. NM2008
    Feb 9, 2008
    135
    Alberto,
    How do I implement this,
    I am new to the PICAXE ic and programming in general, is there any site/link that would demonstrate this type of setup, detailing how to write the code for pulsed inputs?
    Regards NM
