PICAXE 08M2 Problem
Discussion in 'Embedded Systems and Microcontrollers' started by DRock, Aug 31, 2011.
  1. DRock
    May 7, 2011
    68
    Hey everyone,
    I am attempting to tackle my first project with microcontrollers as a recently graduated mechanical engineer, so I really don't know too much about all this stuff YET. I have a breadboard with the PICAXE 08M2 and the stereo jack breadboard adapter from http://www.sparkfun.com/products/8331 and I cannot seem to get it to work.
    I am using the stereo to serial connector but my laptop does not have a serial port so I am using the Dynex serial to USB adapter and the Prolific PL-2303 drivers. I have already used this setup numerous times with my BASIC Stamp and it works just fine.
    I am using the AXE029 breadboard adapter instructions and the PICAXE Programming Editor but when I try to download my program it says: Serial Port Error Code 0x1F54 'Error Reading Comm Device'
    I am not sure where I am going wrong, I don't know if it is a software issue with the drivers I currently have installed or if it is a hardware issue perhaps due to incorrect connections or a sloppy solder joint.
    Do any of you have experience with this setup? I am hoping someone can help me out so that I can begin to test and debug my program.
    Thanks in advance for any help!
  2. DRock
    May 7, 2011
    68
    I am attaching two pictures of my current setup, let me know if you guys spot anything wrong.
  3. DRock
    May 7, 2011
    68
    Guess no one does it this way, where can I get a stereo jack that I can plug into the breadboard? I will just place the resistors on the breadboard and call it a day.
  4. upand_at_them
    May 15, 2010
    246
    29
    Could be an issue with the virtual serial port.
