picaxe 08m2 circuit
Discussion in 'Embedded Systems and Microcontrollers' started by spark8217, May 12, 2012.
  1. spark8217
    Thread Starter Active Member
    Aug 29, 2011
    64
    hi guys
    well started with controllers for the first time , seem to be having a issues with connection and receiving the following error..
    symbol LED = C.0 ' LED on output C.0 (pin 7)
    Error: Unknown symbol - C.0
    i am using a picaxe 08m2 and the following program
    ' =============== HelloWorld.bas ===============
    ' This program runs on a PICAXE-08M2.
    ' It blinks an LED to say "Hello World!
    ' === Constants ===
    symbol abit = 500 ' used to adjust blink rate
    ' === Directives ===
    #com95 ' specify serial port
    #picaxe 08M2 ' specify processor
    ' ============= Begin Main Program =============
    do
    high LED ' LED on
    pause abit ' slow it down
    low LED ' LED off
    loop
    cheers
    spark 8217
  2. spark8217
    Aug 29, 2011
    64
    com 9 not 95
  3. spark8217
    Aug 29, 2011
    64
    Problem solved but thanks ?
  4. BillO
    Distinguished Member
    Nov 24, 2008
    985
    136
    Sorry I didn't see this earlier. Is everything going well?
    So, what did the problem turn out to be? Your code looks fine, except that com95.
    spark8217 likes this.
  5. spark8217
    Aug 29, 2011
    64
    hi
    it turned out to be my software as the older version did not recognize the 08m2 as soon as i down loaded the recent version and fired it up , it worked !! it has the 08m2 listed in the older software that's why i did not realize , it caused me some pain really as i checked and double checked my circuit , board and wiring !!!! anyway happy days but thanks for the reply !!
    cheers
    spark 8217 :):)
