[PIC32MX575] 2 temp sensors TC72 comparing, project, help
Discussion in 'Embedded Systems and Microcontrollers' started by orzeszty, Mar 10, 2016.
  1. orzeszty
    Mar 10, 2016
    Hello.
    I'm new here and i'm student too. I need some help with programming a PIC32. I have project on my university which contains 2 TC72 connected to pic32mx575.
    In this project i must compare temperature live between this two TC72. I read about SPI connections and initizalization and i have some code examples but it's to less to code this.
    I ask you for some pdfs, books, links or code examples. It will be nice if you help me, thanks.
  2. dannyf
    Sep 13, 2015
    2,196
    417
    Forget about reading two tc72. Can you blink a led on your target?
    Go from there.
  3. orzeszty
    Mar 10, 2016
    Yes i can do that. I'm reading "Programming 32-bit Microcontrollers in C - Exploring the PIC32 - Lucio Di, Elseiver" and learning from this book somehow.
  4. ErnieM
    Apr 24, 2011
    7,436
    1,626
    That is an excellent book (I have a well worn copy) but sadly it was almost obsolete as soon as it was published. It has a huge amount of great information but sadly the compiler and libraries have changed.
    The good news is Microchip has an archive download area where you should find the compiler and libraries it works with.
