PIC32 microcontroller c code
Discussion in 'Embedded Systems and Microcontrollers' started by metric_electric, Aug 21, 2013.
  1. metric_electric
    Aug 21, 2013
    19
    Please can someone explain this code to me:
    TRISA = 0x000C; //sets pins RA2 and RA3 to inputs, rest of PortA as outputs
    TRISC = 0xA000; //sets pins RC13 and RC15 as inputs, all else as outputs
    I do not understand how 0x000C represents pins RA2 and RA3 ...and how 0xA000 represents pins RC13 and RC15. I understand binary numbers and a bit of hexadecimal but the above code throws me off.
    Help!
  2. nsaspook
    Aug 27, 2009
    3,020
    2,386
  3. ErnieM
    Apr 24, 2011
    7,443
    1,628
    As nsaspook said, you need to write out the whole 32 bit number in binary.
    I like to see the bit numbers (RA2 or RC15), so I will write them down to construct the binary number. That was lots easier with 8 bit processors, but you can still do it with long words if you write the bit number vertically:
    Code ( (Unknown Language)):
    1. 3322 2222 2222 1111 1111 11
    2. 1098 7654 3210 9876 5432 1098 7654 3210
    3. ----.----.----.----.----.----.----.----
    4. 0000 0000 0000 0000 0000 0000 0000 1100
    5.    0    0    0    0    0    0    0    C = 0x 0000 000C
    6.
    7. 3322 2222 2222 1111 1111 11
    8. 1098 7654 3210 9876 5432 1098 7654 3210
    9. ----.----.----.----.----.----.----.----
    10. 0000 0000 0000 0000 1100 0000 0000 0000
    11.    0    0    0    0    A    0    0    0 = 0x 0000 A000
    12.
    It also helps to separate the bits into hex digits. When I'm doing this a lot I can look at the binary and write the hex digit.
    As a final note, a 32 bit quantity needs a full 8 hex digits to fully specify it.
  4. metric_electric
    Aug 21, 2013
    19
    nsaspook and ErnieM:
    Thank you so much for the explanation, I now fully understand....I spent over week trying to grab that piece of code but you guys broke it down to me in minutes.
    I have another question but it has to do with setting up the software and complier on my laptop.
    I got the PIC32MX795F512L USB starter kit, the I/O expansion board and the cable from the starter kit to a USB port on my laptop. Do I still need the Explorer 16 development board (DM240001) and the MPLAB REAL ICE in-circuit debugger (DV244005)....?
  5. ErnieM
    Apr 24, 2011
    7,443
    1,628
    No and no. The Explorer 16 is a different system where you can change out processors. The USB starter kit has a fixed processor along with a 2nd processor to handle programming and debugging, which means you don't need a separate (ICE) debugger either.
    I'm sure that kit comes with some tutorials. Crack them open and try out the first one.
  6. metric_electric
    Aug 21, 2013
    19
    Thanks ErnieM!
