pic32 bootloader Exception Memory
Discussion in 'Embedded Systems and Microcontrollers' started by chrisw1990, Jan 3, 2014.
  1. chrisw1990
    Thread Starter Active Member
    Oct 22, 2011
    543
    41
    I tried asking stuff in the microchip forum but i got very confused with their layout etc.. hopefully someone here can provide an answer...
    if i have no interrupts in a bootloader.. do i need the exception memory?
    and if i dont.. how do i map this in the bootloader linker script??
    Cheers
    Chris
  2. ErnieM
    Apr 24, 2011
    7,445
    1,628
    Why would this matter? The bootloader runs once before starting your app code, which then sets the memory as it needs be. If the bootloader reserved something the app does not respect this division and uses everything as it needs... as it should be.
    I messed with PIC32 bootloader scripts a few years back. It took forever to get a set that would work and play together. I imagine since MC has changed the compiler or the linker and that work is broken.
  3. chrisw1990
    Oct 22, 2011
    543
    41
    Hi Ernie,
    The issue is that the code cant be overwritten, the exception memory anyway, because that (i assume) will have the function pointers to interrupt routines etc...
    Im just struggling at the moment to identify where the different parts of the code go, and what they do.. the main issue i have is that the KSEG1 and KSEG0 are virtual memory, so does that mean that anything in KSEG0 memory regions cannot be mapped to KSEG1 regions?
    the linker im looking at for AN1388 UART bootloader from mchp seems to put the exception table in the same area as the bootloader C code, so needless to say im a little confused
