pic24 sleepmode power consumption
Discussion in 'Embedded Systems and Microcontrollers' started by jayanthik, Jan 22, 2016.
  1. jayanthik
    Mar 29, 2007
    Hello guys I am using pic24hj128010 for my project which I have to use with battery so I need to reduce current!
    Data sheet says we can reduce consumption upto uA during sleep mode,But in sleep mode uC consumig 1.1mA as I checked on Ammeter, I am confused and dont no where I did wrong!
    But in my PCB even though i have soldered only controller and 5817 schotky diode before the controller supply.
    Regards
    Jayanthi
  2. Picbuster
    Member
    Dec 2, 2013
    391
    53
    where do you measure on the chip or on the power supply in.
    please provide schematic.
    It should draw no more then 50 micro amp on the power supply input.
    With precaution you must be able hit the 10-30micro.
    look at the tris reg status of port outputs and its load.
    switch to low xtal 32khz with a wake up.
  3. ErnieM
    Apr 24, 2011
    7,434
    1,625
    Additionally, when is the last time you checked your ammeter?
    Ever put a 5M ohm resistor to 5V and try to read how much current you see?
  4. NorthGuy
    Jun 28, 2014
    611
    121
    Every TRIS bit set (as it is by default) leaves the input floating, which means it may switch randomly thus consuming power. Therefore, unprogrammed chip may consume quite a bit.
  5. dannyf
    Sep 13, 2015
    2,196
    417
    What are the test conditions in the datasheet for the current spec and do they match your conditions?
