PIC18f67K90
Discussion in 'Embedded Systems and Microcontrollers' started by RG23, Jan 20, 2012.
  1. RG23
    Thread Starter Active Member
    Dec 6, 2010
    301
    I am not able to program PIC18f67K90 with PICKit2
    The program builds successfully in MPLAB IDE v8.36
    But when I try to select the programmer PICKit2, I get the PK2Error0025: Failed to load PICkit2
    and PK2Error0035: Failed to retrieve XML Data(node = %s)
    The program involving PIC18f87J90 built successfully in MPLAB IDE v8.36 and the programmer PICkit2 worked fine too.
    Please let me know how I can get rid of that error?
    I tried to uninstall and install MPLAB but still couldn't make it work.
  2. mik3
    Feb 4, 2008
    4,846
    63
    Does PicKit2 support PIC18f67K90?
  3. RG23
    Dec 6, 2010
    301
    In the MPLAB IDE 8.36
    it does show PICkit2 highlighted in the programmer tab
    few other programmers were not highlighted
  4. mik3
    Feb 4, 2008
    4,846
    63
    Unplug PicKit2 from PC, plug it back and try again.
  5. ErnieM
    Apr 24, 2011
    7,442
    1,628
    I'm up to MPLAB v8.83, and that version shows the PICkit 2 is DOES NOT SUPPORT the PIC18f67K90.
    The PICkit 3 is green and good to go.
  6. spinnaker
    Oct 29, 2009
    5,102
    1,190
    Yep same here but with 8.63. MPLab ICD 2 is green but PicKit 2 is red.
  7. CraigHB
    Member
    Aug 12, 2011
    127
    15
    None of the newer Microchip parts are ever going to be supported by the PICkit2. I fully expect to have to buy a PICkit3 at some point myself, but have not yet built anything with an unsupported MCU. Probably my next project though.
