pic18f46j50 RTCC, can't get it to work.
Discussion in 'Embedded Systems and Microcontrollers' started by bug13, Mar 26, 2015.
  1. bug13
    Feb 13, 2012
    1,213
    38
    Hi guys
    I have trouble setting up RTCC, the idea is to setup an alarm (say 5 seconds later), trigger an interrupt and wake up the MCU.
    Here is my code:
    Code (Text):
    1. void setup_rtcc(void)
    2. {
    3.     rtccTimeDate RtccResetTimeDate;
    4.     rtccTimeDate RtccAlarmTimeDate;
    5.
    6.     RtccInitClock();                            //turn on clock source
    7.     RtccWrOn();                                 //enable write to RTCC registers
    8.     PIE3bits.RTCCIE = 1;                   //enable interrupt
    9.
    10.     //set up clock time
    11.     RtccResetTimeDate.f.hour = 0x01;
    12.     RtccResetTimeDate.f.min = 0x00;
    13.     RtccResetTimeDate.f.sec = 0x00;
    14.     RtccResetTimeDate.f.mday = 0x04;
    15.     RtccResetTimeDate.f.mon = 0x04;
    16.     RtccResetTimeDate.f.year = 0x09;
    17.     RtccResetTimeDate.f.wday = 0x06;
    18.
    19.     //set up alarm time to be 5 second later
    20.     RtccAlarmTimeDate.f.hour = RtccResetTimeDate.f.hour;
    21.     RtccAlarmTimeDate.f.min = RtccResetTimeDate.f.min;
    22.     RtccAlarmTimeDate.f.sec = RtccResetTimeDate.f.sec + 0x05;
    23.     RtccAlarmTimeDate.f.mday = RtccResetTimeDate.f.mday;
    24.     RtccAlarmTimeDate.f.mon = RtccResetTimeDate.f.mon;
    25.     RtccAlarmTimeDate.f.year = RtccResetTimeDate.f.year;
    26.     RtccAlarmTimeDate.f.wday = RtccResetTimeDate.f.wday;
    27.
    28.     RtccWriteTimeDate(&RtccResetTimeDate, 1);             //write time for clock
    29.     RtccSetAlarmRpt(RTCC_RPT_TEN_SEC,1);
    30.     RtccSetAlarmRptCount(0,1);                                        //alarm do not repeat
    31.     RtccWriteAlrmTimeDate(&RtccAlarmTimeDate);       //write time for alarm
    32.
    33.     mRtccOn();        //enable rtcc
    34.     mRtccAlrmEnable();                                                      //enable alarm
    35. }
    36.
    And that's how I test it:
    Code (Text):
    1.
    2. while(1)
    3. {
    4.         if (PIR3bits.RTCCIF == 1)
    5.         {
    6.             PIR3bits.RTCCIF = 0;
    7.             LED2 = 1;
    8.         }
    9. }
