PIC18f45k20 maximum clock speed
Discussion in 'General Electronics Chat' started by Robin Mitchell, Sep 5, 2013.
  1. Robin Mitchell
    Oct 25, 2009
    738
    206
    Hi everyone,
    I noticed that the largest internal oscillator speed is 64Mhz (if you use PLL) but what im trying to figure out is what is the maximum clock speed if you use an external clock? Is it 64Mhz (like the internal oscillator) or can I go higher? Im having a tough time finding this on the datasheet. Any help is much appreciated :D
    All the best,
    Robin
  2. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,383
    Robin Mitchell likes this.
  3. mcgyvr
    Oct 15, 2009
    4,784
    973
    per the features it says
    "Two external clock modes up to 64 MHz"
  4. Robin Mitchell
    Oct 25, 2009
    738
    206
    Fantastic!
    But here is a question, is this 64 before PLL or after PLL???
  5. mcgyvr
    Oct 15, 2009
    4,784
    973
    its 64 MAX...
  6. Robin Mitchell
    Oct 25, 2009
    738
    206
    Awww :(
    But can I? NO
    But what if I..? NO
    Ok
  7. THE_RB
    Feb 11, 2008
    5,435
    1,305
    Try it if you like. I remember in the old days people were running PICs at far above the "max" speed, as much as four times over.
    It will depend on how much you try to bump the speed, how cool you can keep the chip and what failure rate you can tolerate.
