1. sbthree
    Mar 4, 2007
    sir,
    what is the code required convert the ADC output to PWM signal, ie depending on the variation of the analog input i have to change the PWM output. the procedure will be like this first the analog data is converted to digital (10-bit,in 18F4550) and this digital data is used to convert to the PWM signal, how i can adjust the dutycycle depending on the analog input variation.
    pls help me in this topic
    sreejith
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    You may be laboring under a misapprehension. We do not write custom code on demand. That is your job. However, we may be willing to look at your work and offer advice.
